3CX MyPhone and Outlook2013
Discussion in '3CX Phone System - General' started by linking13, Nov 5, 2012.
  1. linking13
    Nov 14, 2008
    44
    Since Office 2013 RTM is released to TechNet, MSDN Subscribers there are any compatibility issue between the new version of Outlook and the MyPhone add-in for Outlook? Can I integrate 3CX MyPhone with Outlook like in the 2010 version of Outlook?
  2. linking13
    Nov 14, 2008
    44
    I give a first answer about this topic. The Add-in seems works fine if enabled after Outlook is started, but if I close and re-open Outlook 2013 I notice a very slow process opening the problem and the Add-in must be reactivated.
    For the moment seems that the best way is to enable the add-in after Outlook is started and disable it before closing the program.
    Any news about a new version that is compatible with 2013 version?
  3. rock2
    Apr 23, 2012
    I'm also experiencing this behaviour.
    Would be interested in a fix.
    Currently running 10.0.22686.2297
  4. linking13
    Nov 14, 2008
    44
    I'll confirm that the only solution seems to be the 3CX11 SP4. All other attempts are not supported and works till next restart of Outlook
