3cx MyPhone loggin
Discussion in '3CX Phone System - General' started by jeroen streutker, Jun 1, 2011.
  1. jeroen streutker
    May 17, 2011
    7
    Have problems logging into myphone.
    get the message Can not connect to server.
    what should I do.
    it works on the machine running 3CX on.
    a PC on the same network gives this message.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    sounds like a firewall issue, can you disable the firewall on the 3CX Box and test again and confirm?
  3. jeroen streutker
    May 17, 2011
    7
    Hello David,
    192.168.0.9:5000 / 3cx interface works.
    192.168.0.9:5000 / myphone wont work.
    the problem is not the firewall otherwise the web interface wont work.
    have the firewall disabled.
    what can it be.
  4. davidbenwell
    Apr 27, 2010
    704
    not sure without logging in remotely to run some tests etc.
    have sent you a PM
  5. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    52
    Jeroen,
    Did you have this problem before or after you reinstalled the 3CX Phone System?
  6. davidbenwell
    Apr 27, 2010
    704
    Things to try on a PC on the same network
    * Uninstall Silver Light
    visit the URL of MyPhone and see if you are now able to connect
    if prompted install silver light and see if you are then able to connect.
  7. jeroen streutker
    May 17, 2011
    7
    Hello Frank,
    have the problem before and after reinstalling the 3cx system.
  8. davidbenwell
    Apr 27, 2010
    704
    Have you tried uninstalling Silver Light and reinstalling? or at least clear the Application Storage info within Silver light?
  9. jeroen streutker
    May 17, 2011
    7
    Hello 3cx friends,
    SilverLight reinstall no change.
    The strange thing is I do get the login screen.
    no phone number I can login.
    Password okay gecheckd one hundred times.
  10. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    What is the webserver in question?
    Can you try and restart the webserver?
  11. jeroen streutker
    May 17, 2011
    7
    using abbys server.
    reboot make anything out. :(
  12. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    I dont understand your last post reboot make anything out.
    Restart the webserver.
    clear the cache of silverlight (right click silverlight, application storage, delete all, make sure application storage is checked) and try again.
    If it does not work let me know and send me the myphone log located in my documents.
    Does it work on other machines?
    Alternatively you might have a corrupt silverlight installation - Remove silverlight (right click and remove) and install again
    keep me updated
  13. jeroen streutker
    May 17, 2011
    7
    doens's make a difference
    only on the 3cx machine
    can't find the log
  14. davidbenwell
    Apr 27, 2010
    704
    i think you need someone to log in remotely and take a look at this for you.
  15. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Make a wireshark capture - Can you see whether data is coming to the machine from port 5000?
    Can you delete browser cache too. I think that the login screen is an old cached login page.
  16. Sopock
    Sopock Member
    Jul 11, 2012
    444
    20
    same problem with version 11! :S
  17. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    So this didn't work for you for a full year - last post was June 2011. ???
  18. Stef - Venema Advies
    Apr 10, 2012
    26
    I had the same problem.
    Because of the automatic backup the disk was full.
    after i cleaned the disk everything was working.
