3CX MyPhone logs out auto at 11.00pm.
Discussion in '3CX Phone System - General' started by pacpac, Feb 12, 2012.
  1. pacpac
    Jan 12, 2012
    58
    Hi, 3CX MyPhone logs out automatically at 11.00pm every evening. Is there a way I can configure I am logged in contously 24 hrs?
    11,092
    327
    What do you mean? It is in a queue and actually logging out, or a set just not re-registering? What does the log show?
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Have you checked your office hour settings?
  4. pacpac
    Jan 12, 2012
    58
    Hi, the reason for the log out was apparantly that Abyss resets at 4.00am (the reason for 11pm is time difference between my location and server location). Also, I understand that it would be a 5-6 secs delay for the first call to an IVR to kick in after Abyss reset. I have re-installed 3CX to use IIS, and I hope this will not occur again.
