3CX MyPhone shows CID as Private Number
Discussion in '3CX Phone System - General' started by habros, Jul 26, 2012.
  1. habros
    Jul 25, 2012
    5
    Hi all,
    When a call comes in, CID works/shows properly until it hits Que. After that MyPhone show CID as as Private Number while the 3CXPhone still got the proper CID. Any idea?
    TIA,
    Dave
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Seems that this is by design. Regular users can not see CID of other users. Or, this can be a bug... I have the same problem, by the way.
  3. igor.snezhko
    Jan 7, 2008
    668
    7
  4. habros
    Jul 25, 2012
    5
    I cannot see my own CIDs after call passes que. If it's not only me who is affected than it's a bug as it breaks outlook and crm integration.
  5. StefanW
    Jun 2, 2009
    1,222
    93
    check in the group rights, there is a new option, hide caller id from queues. disbale it and you will the the number as in V10
  6. habros
    Jul 25, 2012
    5
    Stefan,
    I see option for hiding CID under Extensions > [extention] > Other > 3CX MyPhone Options, however I cannot find the option that you are mentioning (for groups). Where is it?
    PS
    Changing CID hiding under Extensions does not make any difference.
    TIA
    Dave
  7. StefanW
    Jun 2, 2009
    1,222
    93
    the right i am talking about is located in the group rights.
    click under ext on a group and you will see the rights of this group
    you can not set rights for the management group (sees by default everything) and non group members coz they simply dont have a group ;-)
  8. habros
    Jul 25, 2012
    5
    Stefan,
    I had only MANAGEMENT group and as you mentioned and it did not have any settings available. I've created a new group with the permission enabled (unchecked) and add every extension to it. CID works now, thank you.
    Based on the info above, it seems that MANAGEMENT group has this setting "Hide CID..." disabled by default. Any way of editing some configuration file to change this behavior?
    TIA
    Dave
  9. StefanW
    Jun 2, 2009
    1,222
    93
    by default all options are "enabled" for the MNG group.
    Did you used any Beta Versions of the V11 before the Final and uses the backup since?
  10. habros
    Jul 25, 2012
    5
    Stefan,
    This a fresh install of the Windows Server and 3CX on Hyper-V.
    - Windows Server 2008 R2 Standard SP1 with all the updates and patches.
    - 3CX Phone System v11.0.26364.600.
    Dave
  11. LukaszW
    Jun 24, 2013
    Hi Stefan,
    Have you found a solution to that issue, please?
    I have just tried the same functionality and CID comes up on the phone and stays correct within 3cx but MyPhone shows a Private Number for all incoming calls.
    I checked the tick boxes you mentioned to "Hide Caller ID information in 3CX MyPhone" which are un-ticked (I only have one group anyway).
    Any suggestions much appreaciated.
    I am working on 3CX v11 with SP4 and Outlook 2013
    Thanks,
    Lukasz
