3CX No Audio in Call
Discussion in '3CX Phone System - General' started by computerforce, Jul 7, 2014.
  1. computerforce
    Jan 25, 2013
    Hey guys,
    Was wondering if anyone could give me some quick advise.
    We have a customer with 4 stores. (A main store and 3 sister stores). Sometimes calls going between the sister stores (Extension to Extension) end up with no audio. Mostly no audio both ways but sometimes one way.
    They have Cisco routers and a always on SITE-SITE VPN back to the main office where 3CX V12SP6 is on a 2012 Server.
    I saw after a bit of a google that the tick box "PABX delivers audio" might help.
    Any ideas?
    Antony
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Certainly a network configuration issue.
    Some recommend the SIP Proxy Manager at your branches.
    Assuming the PBX is in the main office.. are the branches set as remote extensions or local extensions? (is the address they register to the PBX WAN address or the LAN address)
    I have gone either way, given their PBX was in a colo and some sites had a site-to-site VPN.. another did not.
    Last.. a SIP ALG may help... or may hinder... your remote extensions. At home.. it helps a bunch between the soft phone on Windows, the soft phone on Android, and a handset.. all of which connect to different/muliple installs at multiple clients.
  3. leejor
    10,375
    231
    A single extension , alone, at each of the sister stores does not ring any alarm bells, and on the surface, should work. That said, it may be, as mentioned previously , a router setting at one, or more, of the sites. Do they all VPN back to the main store?
    Could there be any other VoIP devices deployed at the sister sites that might be "using" the voice ports?
    Besides the PBX delivers audio option, you might try (if not already set this way), giving each of the sister store phones a fixed IP and trying some port forwarding at the remote routers.
    This is all being said, not being clear on your entire network set-up, so please keep that in mind.
  4. cyberspot
    May 12, 2008
    87
    I have succefull installed 3cx in 12 sites in the past with cisco routers and it worked just fine. You will have to be very carefull with routing and i will advise you to enable a routing protocol so all routers will know where are the other routers.
    Or you will have to make static routes in every router for every router that you have.
  5. computerforce
    Jan 25, 2013
    Thanks for the reply guys!
    Our Cisco's are programmed by a special company, we don't program them. I contacted 3CX and they recommended ticking that PBX Delivers audio and unticking the two under it.
    We'll see if this help :)
  6. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    We always select pbx delivers audio for external handsets as default......
