3cx not registed
Discussion in 'Android' started by franku, Oct 3, 2011.
  1. franku
    Oct 3, 2011
    I just download 3cx 1.32 for android
    it give me not registed error
    my configuration is as follows:
    name: is my name
    display name: is my name
    user: is my ext
    id: is my ext
    password: is my password
    internal server has nothing
    external server the ip of voip server everything else is defaulted
    anything I missing or should change?
    10,779
    286
    Yes..... the type (make/model) of phone you are using, version of Android, are you trying to connect over 3C or WiFi, and with the 3CX PBX or a VoIP provider?
    If with the 3CX PBX, do you see any sign of a registration attempt in the logs?
    (As far as I know the internal server IP should be datafilled if using 3CX PBX)
  3. rcinfo
    Nov 18, 2008
    6
    I have the same problem, using tunnel to connect with my Galaxy S to a remote 3cx phone system via wi-fi
    I notice that I cannot set the "Local IP of remote PBX" because it is 'grayed'
    I have another softphone on my pc that connects regularly using the same parameters, the only difference is that here I can set the 'local IP of remote PBX'
    can you help?
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,481
    67
    When "Local IP of remote PBX" is grayed it means you're "in office" and the tunnel will use the "local IP" you already specified.
    "Local IP of remote PBX" becomes enabled when you're "out of office".
