3CX not registring with VoIP provider
Discussion in '3CX Phone System - General' started by 9009, Jun 19, 2016.
    Jun 19, 2016
    32
    I have installed 3CX v14 on Windows 10 PC, have forwarded all of the required ports and the Firewall Checker passed. However, I can NOT get it to register with a 3CX supported VoIP provider (CallCentric).
    I have checked the VoIP authenticating info and that is correct. I do not have any phones installed yet.
    What am I doing incorrectly?
    10,758
    286
    What (error?) does the 3CX server log show after a registration attempt? There should be an indication in there about what the issue is.
  3. 9009
    Jun 19, 2016
    32
    Here is what I see in the Activity Log:
    18-Jun-2016 22:51:43.431 [EC100002] Connection with media server is lost
    18-Jun-2016 22:51:41.911 [EC100008]: Connection with TunnelService is lost
    18-Jun-2016 22:51:40.524 [EC100005]: Connection with Parking Orbit server is lost
    18-Jun-2016 22:51:35.204 [EC100006]: Connection with Conference server is lost
    18-Jun-2016 22:51:34.260 [EC100004]: Connection with IVR server is lost
    18-Jun-2016 22:51:31.238 [EC100007]: Connection with QueueManager is lost
    18-Jun-2016 22:51:29.286 [EC100003]: Connection with FAX server is lost
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Those are the internal modules that drive 3cx. These are typically stopped when running the firewall checker. You need to restart them in order for normal operation of the PBX functionality to resume. You can do this by going to system services and restart all or by rebooting the system.
    It was not clear in what order you tried to connect to your provider, before or after the firewall test. You may also need to check any firewalls that are installed on the machine where 3CX is installed (windows or 3rd party) and either make provisions for the same forwarding or turn-off.
  5. 9009
    Jun 19, 2016
    32
    Ineblett, thank you very much for your help, it works. The Firewall Checker had stopped the internal modules and I had to restart them for PBX to register with my VoIP provider.
  6. anjanavj
    Jun 28, 2016
    7
    Thanks to Inbelt I too had a same problem now it's working fine now I'm getting best voip service through 3cx
