3CX not releasing mic correctly under Vista?
Discussion in 'Windows' started by mrgodber, Jul 16, 2008.
  1. mrgodber
    Jul 16, 2008
    When the client is first opened, the first call works fine. However on subsequent calls the person at the other end of the line cannot hear me. If I open and close the Vista sound recorder or speech recognition utils in between (without closing the client), the next call does work.
    Is there a problem with 3CX closing the microphone connection correctly in Vista?
