Solved 3CX not switching to HOL IVR
Discussion in '3CX Phone System - General' started by TCF, Nov 27, 2017.
  1. TCF
    TCF
    May 6, 2015
    92
    Over our Thanksgiving break 3CX did not use the HOL IVR. Instead it used the Office Closed IVR as if we were just outside regular business hours, even during normal business hours. I'm not sure if this is a bug or if there is something I'm missing? I'm running the latest release of 3CX.
    Any ideas?
  2. V..
    V..
    Feb 14, 2017
    76
    29
    Hi TCF, please could you provide a screenshot of the holidays table from your PBX?
  3. V..
    V..
    Feb 14, 2017
    76
    29
    I agree this should be the case, are global holiday hours enabled on both the trunk and extention\queue\ring group?
  4. TCF
    TCF
    May 6, 2015
    92
    It seems you may have found the problem. I didn't have Play holiday prompt when it's a global holiday checked on the Trunks. Is this a new feature in V15?
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,819
    564
    Glad to hear the issue is resolved. This is not a new feature of V15 as it was present at least in V14 also.
