3CX not updating
smeego78
Hi team,
I'm helping a colleague set up a 3CX box but it doesn't appear to be updating. What ports do I need to open on the firewall? the standard ftp ports??
Please let me know.
thanks,
Jax
Here is a link to the ports that 3CX uses, and exactly what they are used for....
http://www.3cx.com/blog/docs/ports-used/
This might be worth a read as well...
http://www.3cx.com/docs/firewall-router-configuration-voip/
I would consider the following:
Is your browser using any kind of proxy?
If so, it might be worth trying to disable it, as your proxy might be filtering access to the web
Ensure that you are using a fully supported browser like Firefox or Chrome
In order to update the software, you only need to be concerned with 'outbound' ports
Getting Started - Admin
NYCTECHZONE
Get 3CX - Absolutely Free!
3CX
