3cx not work with gateway fxo
Discussion in '3CX Phone System - General' started by awcalien8, Mar 24, 2008.
  1. awcalien8
    Jan 29, 2008
    6
    3cx not work with gateway fxo.
    I am disappointed with the 3cx.
    I tried
    Dlink DVG 6004S
    Grandstream HT488
    And the same problems happened .... By hanging up calls, noise, fails.
    And these gateways work perfectly with asterisk-tribox.
    I am dropping to work with the 3cx.. :cry:
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    HI
    IT'S NOT 3CX PROBLEM IT'S GRAND STREAM
    I USED LINKSYS SPA3102 AND IT WORKS VERY FINE
    ALSO GRAND STREAM GXW4104 VERY GOOD
    BUT GRAND STREAM HT503 (LIKE 488) HAS SOME ISUES
  3. Halea
    Halea New Member
    Jan 5, 2008
    151
    Sorry to hear about your troubles. I spent quite a bit of time with HT488 and got it to work reasonably well. I posted my settings on this forum. Please do a search with my name, you will find it for sure (it was only a few weeks back). Give a try and see if you can make things work.
    In all fairness to 3CX, most problems are with HT488. Linksys 3102 works better and is much simpler to setup.
    When everything is running optimally you might still have some echo when you call out on PSTN. With HT488 setup to work with 3CX, you won't be able to use the handset attached to its FXS port to place a call out on FXO port via 3CX. It's a design limitation of HT488. You won't receive CID either with HT488.
    Good luck.
    Halea
