3cx office 365 Impersonated Account
Mickel den Ouden
I have a 3cx version 15.5.93.48.3.
I want to have my office 365 contacts in 3cx.
I followed the guidelines in https://www.3cx.com/docs/how-to-create-impersonated-user/
after that i followed this link https://www.3cx.com/docs/manual/pbx-crm-integration/
Configuring the Exchange Connector (MS Exchange Sync)
But the contacts wil not turn up in my 3cx.
After i have dowloaded the 3cxSystemService.log i found the following error:
018/03/20 13:56:49.479|10658|0054|Excpt|Microsoft.Exchange.WebServices.Data.ServiceRequestException: The request failed. The remote server returned an error: (401) Unauthorized. ---> System.Net.WebException: The remote server returned an error: (401) Unauthorized.
Can somebody tell me what the problem is ?
Moving back to the General forum, as the question is not related to a CRM plugin, but to the contact synchronization feature.
You're getting a 401 Unauthorized error, that means a problem with the credentials provided, or the user not having permissions to access the resources you're trying to access...
Do i need to turn off the advanced security in office 365 and use the basic to makes this work on a linux based 3cx ?
this has nothing to do with it, but depending on the user you created or use for the impersonation, I would reuse already a user you have to save on the fee, be sure that the user account is licensed to use the exchange service!
If I have only one user in office 365 do i also need to make a impersonated-user or can i just use that one user with login and credentials ?
you can use any account you have - which is entitled to access exchange.
This can be a dedicated user (advice for a local exchange) or an existing (advised for office 365 to save $$$). Just note, if you change the password, change it also in the PBX!
Getting Started - Admin
norb.p
Get 3CX - Absolutely Free!
3CX
