3CX offline backup question
Discussion in '3CX Phone System - General' started by garyjduk, Aug 12, 2017.
  1. garyjduk
    Aug 11, 2009
    70
    Is there a way of doing an offline 3cx backup as I cannot get into the Management Console? The system is running but I have no access as it gives an error.
    I cannot access the console due to SSL Certificate error and need to uninstall and reinstall to sort this out.
    I'm running V15.5 but not the SP1 which I see now has this facility.
    https://www.3cx.com/docs/backup-restore-command-line/
    Gary
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    878
    135
    Are scheduled backups configured and running ?
    Ver 15.5 does not have a command line backup.
    Have tried http instead of https, IP address of server not sure if this works but worth a try
  3. garyjduk
    Aug 11, 2009
    70
    No that won't work as Nginx service won't start due to the SSL Certificate.
  4. Saqqara
    Mar 12, 2014
    878
    135
    Not sure where the config is stored, probably Nginx so if this is not working then you will have issue doing a manual backup if this was possible
    Maybe worth a call to 3cx if you have support
  5. us1
    us1
    Oct 19, 2015
    80
    21
    Edit the nginx configuration and comment out the SSL lines. Save and restart nginx.
