3CX offline installation
Discussion in '3CX Phone System - General' started by Ralph Neser, Dec 19, 2016.
  1. Ralph Neser
    Dec 19, 2016
    we do have a closed system. No internet connection.
    We would like to install 3CX but there is a requirement for a internet connection.
    Does any possibility exists for an offline installation without any Internet connection?
    I have tried to install it but without any success as the 3cx DNS entries couldn't be resolved on my system.
    Thanks beforehands,
    Ralph
    JohnFuchs likes this.
    11,105
    329
    I assume that the past requirement is the same for version 15 in that an internet connection is required, at least for the initial installation. From time to time, as I understand it, a licence check is done.
