3CX on a Terminal Server
Discussion in '3CX Phone System - General' started by Cynthia Slade, May 30, 2012.
  1. Cynthia Slade
    Mar 22, 2012
    45
    We have a new 3CX install tomorrow (present system died today) In anticipation of going from V10 to V11 we are considering installing on a 2003 server presently being used as a terminal server (for 1 user only). Has anyone installed on a TS and/or are there any problems in doing so? Only other servers are running SQl and Exchange. Thanks for all feedback!
    11,116
    329
    The most important considerations would be the speed of the processor, the amount of memory and hard drive space available.
    http://www.3cx.com/blog/docs/supported-windows-versions/
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    I am afraid more detail is needed. You don't indicate how big a 3CX install nor how the 2003 server is configured. More than likely, you are good to go, but without knowing more, there is some possibility of a problem.
  4. Cynthia Slade
    Mar 22, 2012
    45
    Thank you for your replies. Sorry I was not clearer that my concern was with a possible problem/conflict with Terminal Server Services running on the same server. The 2003 server has more than adequate prossessor, hard drive and memory. This is a very small install (under 10 users). Thanks again
  5. netswork
    netswork Active Member
    Mar 11, 2011
    577
    As long as you install 3cx under the administrator account you should be fine. I also would not install it with the server in install mode, like you normally would with applications on a terminal server. There should be no need for the terminal service user to access the 3cx application.
  6. Cynthia Slade
    Mar 22, 2012
    45
    UPDATE: Installed on Terminal Server and all is working just fine.
