3CX on Android phone
Discussion in '3CX Phone System - General' started by Pieter Eijkmans, Jun 21, 2013.
  1. Pieter Eijkmans
    Jun 21, 2013
    Hi, when using the 3cx android client on my Samsung with wifi presence and call history are working fine. But when using the tunnel connection both options don't work.
    Did i misconfigure something or will this be fixed in the future ?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,416
    277
    maybe along the same line as your issue?
    http://www.3cx.com/forums/no-tunnel-for-presence-35018.html
  3. Pieter Eijkmans
    Jun 21, 2013
    Forwarding port 500 did the trick, but it would be nicer if this traffic would also use the tunnel connection.
  4. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Indeed it would. ;)
    The tunnel isn't exactly the most secure, either.. but it would certainly make my life easier if the MyPhone did..
    To the feature requests!
  5. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    i configured 3cx phone on android, i also configured push notifications on 3cx from manual, send email with configuration to 3cx phone and eveything is working. Question: do I need something to do on android phone to activate push messages? or just on the server side like manual says?
  6. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    Update:
    when configuring 3cx phone via mail (config fail) presence list are not working -> 3cx phone is not even sending the request to my router ->firewall rule doesnt have matches. When i create extension manually i get matches in firewall rule (port forward tcp 5000). Also how to be sure that push is configured for my softphone on android, can push be configured for 3cx phone on android which are not configured with provisioning file from 3cx
