3cx on azure
Discussion in '3CX Phone System - General' started by infused, Nov 16, 2016.
  1. infused
    Oct 17, 2013
    19
    I don think this is an azure issue. But completing the install on Debian 8 I get the following error
    System.Exception: Error in CreatingCloudServerManagementDatabase.sql: 22023: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) ---> Npgsql.PostgresException: 22023: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) at Npgsql.NpgsqlConnector.DoReadMessage(DataRowLoadingMode dataRowLoadingMode, Boolean isPrependedMessage) at Npgsql.NpgsqlConnector.ReadMessageWithPrepended(DataRowLoadingMode dataRowLoadingMode) at Npgsql.NpgsqlDataReader.NextResultInternal() at Npgsql.NpgsqlDataReader.NextResult() at Npgsql.NpgsqlCommand.Execute(CommandBehavior behavior) at Npgsql.NpgsqlCommand.ExecuteScalarInternal() at PostInstall.DBConnection.ExecuteScriptInternal(NpgsqlConnection connection, String sqlQuery, IDictionary`2 parameters) at PostInstall.DBConnection.ExecuteScript(String sqlQuery, IDictionary`2 parameters) at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) --- End of inner exception stack trace --- at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) at _3CXCloudDBManager.CloudDBManager.CreateCloudServerManagementDatabase(IDBConnection superuser, CloudServerManagementDatabaseConfiguration configuration) at PostInstall.SetupExecutor.CreateDatabase(Action`1 stateChanged) at PostInstall.SetupExecutor.ExecuteSetup(SetupSettings setupSettings, Action`1 stateChanged) at PbxWebConfigTool.PbxSetupService.CreatePbxInternal(SetupSettings settings)
  2. viptelecoms
    Nov 17, 2016
    Hello mate,
    Do the following:
    Code:
    sudo apt-get purge locales
    then:
    Code:
    sudo apt-get install locales
    and the famous:
    Code:
    sudo dpkg-reconfigure locales
    and choose
    Code:
    en_US.UTF-8
    Reboot the machine and everything should be OK.
  3. infused
    Oct 17, 2013
    19
  4. infused
    Oct 17, 2013
    19
    All working good, but still an issue with outbound phone calls being dropped after 32 seconds. Not sure which firewall rules etc need to be changed? I have all the defaults configured.
  5. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Dropping a call after 32 sec is typically a firewall or NAT issue. You can debug it with wireshark, some SIP packets are lost, 32 sec is a timeout.
