3CX on Blackberry
Discussion in '3CX Phone System - General' started by saben, Oct 7, 2014.
  1. saben
    Oct 7, 2014
    Is anyone using 3CX on blackberry? Couyld you kindly provide some info on how to install?
    Thanks,
    Ben
  2. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    unfortunately the 3cx client is available only for Android and iPhone for now. You may upload a feature request on our site and if it gets enough votes it will be included on the next upgrade. You may find the link no our website : http://www.3cx.com/ideas/index.php
  3. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    Third post:
    http://www.3cx.com/forums/blackberry-18175.html
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    Hi there,
    Well the fact still stands that currently there is no 3CX Phone client for Blackberry, but the forum post you linked us to says that some people used a 3rd-party application that runs on Blackberry and registered an extension using that.
    This does sound possible as you can manually register most softphone clients, however there is no guarantee the all functions (blind transfer, attended transfer, hold, etc) will work as intended obviously as the software is not developed by 3CX.
    If you are an owner of a Blackberry the best way to check if it works or not is to try it. Some people say they have done it, so maybe you could PM one of the users that have allegedly got it running.
    Keep in mind though that using 3rd party software and/or non-supported deskphones phones may or may not work, but 3CX Support won't be able to help if you run into any issues.
