3CX on D-Link / configuration?
Discussion in 'Windows' started by raad, Jun 23, 2008.
  1. raad
    Jun 23, 2008
    I have bought a D-Link DVG-6004S VoIP gateway so I can use SIP features using 3CX. I have been trying to configure it to use SIP phone feature for 4 SIP outlets. But I could not configure it. I have also tried to transfer my office telephone on this gateway so I can use it as a router for normal telephone calls. I have been successful to define several extensions, and make calls using 3CX softphone. I have also received calls, but I cannot hear or speak (no audio transfer).
    Has anyone had any experience using a D-Link gateway with 3CX? How should I configure the settings? Which parts are essential?
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    is this extensions local or wan
    any way no voice after ring means port problems
    so check server ports (firewall) also the router ports if you use wan
  3. raad
    Jun 23, 2008
    We are using the extensions local, and we are not using WAN.
    Could you please specify which ports should be checked, or even how?
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    Are the extension to extension calls not working or are the external (incomming and outgoing) not working?
    H.
