3cx on exchange
Discussion in '3CX Phone System - General' started by akourou, Jul 11, 2009.
  1. akourou
    Oct 20, 2008
    10
    I have a server with windows server 2003 installed.
    It acts as: exchange server 2003, web server, dns server, dhcp server, domain controller, file server
    Can I install 3cx system on that server or there are compatibility or port issues?
  2. home
    Feb 25, 2009
    31
    Are you refering to Win 2K3 SBS, if so you can install to it, there are some minor issues, I would recommend using the 3CX web server rather than IIS.
    I am successfully running 3 installations on this operating system.
  3. zanthexter
    Jun 30, 2009
    11
    Have you had any issues with call quality due to other activity on the SBS? BAckups, Virus Scans, that sort of thing?
    Personally I like the idea of a dedicated box, even a cheapo $300 PC, because if my server goes down, it's nice to have the phones up to call tech support :)
  4. akourou
    Oct 20, 2008
    10
    no, I dont mean the sbs. I have the server2003 installed, and the exchange 2003 intsalled on it.
    Also IIs, dhcp, dns, and active directory services are enabled.
