3cx on Microsoft Server 2008
Discussion in '3CX Phone System - General' started by shark95763, Mar 5, 2008.
  1. shark95763
    Aug 22, 2007
    22
    Hi people,
    Does anyone have experience or know if 3cx runs on a windows 2008 server?
    regards,
    shark
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    If you are comfortable with this very new system - make try. I would not recommend to use it so early.
    But big anvantage of 2008 is a feature to work without GUI. This is very good for VOIP platform.
  3. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    Just try how it works, and maybe you can setup just a few providers for testing, put the logging on verbose, and see how it goes from the beginning with starting all the services etc.
    I really think it shouldn' t be a big problem at all. Just check if 3CX gave you as the administrator all the rights for the Database etc. A newer Windows Server means normally, more security, more configuring.
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I have a spare server with 2008 on it. I will give it a try and let you know very soon. Unless you want to run it on a virtual machine running 2008 as core won't work, at least I don't think so. I'll try that as a 2nd test but it will take a bit longer since i have to format and re-install.
  5. oldknock
    Feb 14, 2008
    I am very interested in this topic. You go, RobLloyd!
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I think I have some time now to give this a full workout.
    What do you guys want to hear about first? I have 2008 already installed with the full gui. A core install might be 2nd.
    I will post installation problems, firewall issues/tweaks, etc. I don't make or receive many calls but I will test out what I can using NexVortex.
