3CX on Patton 4638 with OLD configuration
Discussion in '3CX Phone System - General' started by AndreaES, Jun 27, 2012.
  1. AndreaES
    Jun 22, 2012
    I need to upgrade my PBX System with 3CX.
    Now i have 3 SIP Gateway in my startup configuration.
    PBX [192.168.150.1]
    Patton 4638 [192.168.150.2] with firmware 4.2.
    Patton 4112 [192.168.150.3] only for fax.
    How do I configure 3CX?
    The file generated is only for firmware 5x.
    Log:
    Code:
    17:46:28.477  [CM102001]: Authentication failed for SipReq:  INVITE 070650889@asterisk tid=42037caf5 cseq=INVITE contact=070680582@192.168.150.2:5062 / 1472514940 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    17:46:28.476  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      INVITE sip:070650889@asterisk SIP/2.0
      Via: SIP/2.0/UDP 192.168.150.2:5062;branch=z9hG4bK42037caf5
      Max-Forwards: 70
      Route: <sip:192.168.150.1:5060;lr>
      Contact: <sip:070680582@192.168.150.2:5062>
      To: <sip:070650889@asterisk>
      Call-ID: 62ad6f7aa272494d3d27e89ffc78b100@asterisk
      CSeq: 1472514940 INVITE
      Session-Expires: 1800
      Proxy-Authorization: Digest response="1027e4fdb7962bf0d03501990eb40170",username="patton2",realm="3CXPhoneSystem",nonce="414d535c05fa6a5487:f0738ee82f316e8b7003e7c080dea130",algorithm=MD5,uri="sip:070650889@asterisk"
      Supported: timer, replaces
      User-Agent: Patton SN4638 5BIS MxSF v3.2.8.45 00A0BA041CF4 R4.2 2007-09-19 H323 SIP BRI
      Content-Length: 0
    17:46:28.476  [CM302002]: Authentication failed due to unidentified source of: SipReq:  INVITE 070650889@asterisk tid=42037caf5 cseq=INVITE contact=070680582@192.168.150.2:5062 / 1472514940 from(wire)
    17:46:28.345  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      Via: SIP/2.0/UDP 192.168.150.2:5062;branch=z9hG4bK8bb038724
      Max-Forwards: 70
      CSeq: 1472514939 INVITE
      Content-Length: 0
