3CX on Samsung Galaxy SII LTE
Discussion in 'Android' started by fmalerts, May 18, 2012.
  1. fmalerts
    May 18, 2012
    I am running the latest version of your client on Samsung Glalaxy SII LTE ( Android 2.3.5 - kernel
    I'm using it with a canadian voip provider (freephoneline.ca). Your client works well if I am using it via a wi-fi connection. When I turn off wi-fi and use only the data network from the telco (rogers.com) the 3CX client is able to register with the voip provider. I can start a call and eventually the call becomes active but I can not hear the person at the other. That person can hear me (the mic works but the speaker doesn't).
    Again, this behaviour is not happening through wi-fi, it works perfect that way.
    At first I thought the problem it's with the telco not supporting VoIP over their data network, but they swear that they don't block anything. I still don't believe that's the case. Do you have any suggestion on what I can do to make it working? Or do you have a way where I can enable logging and gather more details so I can show the telco ?
