3cx on Windows IoT
Discussion in 'Ideas' started by troosters, Mar 5, 2016.
  1. troosters
    May 8, 2014
    17
    Hi, it would be nice to have 3cx running on a Windows IoT version when using a 4SC (or 8SC) , this way the 3cx-server can be installed on a Rasperry Pi 3 :)
    Just to cut down on costs :)
    This would turn over even a lot more clients as it does not need to be run on a expensive Windows machine for very small companies who do not even own a server.
    Server are even becoming old-school with the Cloud and Office365 coming in with the speed of light.
    11,129
    330
    It certainly looks interesting. I'm wondering if it isn't a bit too "simplistic" an operating system to handle 3CX. All Windows 10 versions are not created equally.
  3. troosters
    May 8, 2014
    17
    yes off course. I don't know how IoT looks like, if it is just a core version with only Powershell on it, then it will be difficult to manage. Allthough a webbrowser can access it from another device, so maybe it is doable?
