3CX on Windows Server 2008 R2
Discussion in '3CX Phone System - General' started by noelpastor, Oct 13, 2016.
  1. noelpastor
    Oct 13, 2016
    Hi. My company is doing a proof of concept of 3CX server using the Enterprise edition. The admin guide lists all Windows OS supported including Windows desktop and server versions. As this system will eventually potentially support hundreds of employees I prefer to run 3CX on robust sever OS specifically Windows Server 2008 R2 w/c is the current standard server OS of my company. Would appreciate comments from folks regards running 3CX on this Windows version.
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    We are running on Windows 2008 R2 just fine.
  3. noelpastor
    Oct 13, 2016
    Thanks just installed 3CX on Windows Server 2008 R2 and fine so far.
