- Joined
- Sep 28, 2012
- Messages
- 1
- Reaction score
- 0
Good Morning
I have a problem with 3CX MyPhone Software local installed on machines.
In our company we most use normal Windows 7 PCs with the software. They work very well. Now we are changing some of the PCs to XenDesktop.
The Problem is now: I can install the Software the normal way on the virtual PC but if i logout and login again, the Program gives an error message like "There is a communication problem between this computer and the server.... reinstall the software". When i reinstall the Programm, all works fine until i logout (or restart computer) and login again. The same error appears.
My Problem is that i not can teach the users to reinstall this software every mornig ;-))
Thanks for help!
Thanks for help!
