3CX Oneway Audio Issue with WatchGuard x750e
Discussion in '3CX Phone System - General' started by xchen, Sep 25, 2014.
  1. xchen
    Aug 1, 2014
    8
    Hi all,
    I can't get it working with WatchGuard x750 firewall box for 3CX phone system.
    We have:
    1, 3CX Phone System Server in Data Centre (Outside of Office)
    2, Some 3CX compatible phones in office
    Without any firewall policies, I was able to make calls, but only one way audio:
    Office phone calls a customer
    Office can't hear from customer
    Customer can hear
    Looks like to me makes sense, then I set up a policy to allow traffic from office to external on port 3478,5000,5060,5009,9000-9049 (TCP&UDP), still doesn't work!
    Googled, people say I should disable ALG proxy or something from WatchGuard - I don't see it is enabled in anywhere, nor I can find a place to disable it.
    Any suggestions or direction will be much appreciated!
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Youre very likely having a NAT issues most likely resulting from SIP ALG, if you cannot find it to disable I'd suggest you open a ticket with Watch Guard or get with someone who knows the device well as they can assist in disabling SIP ALG for you.
  3. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    7
    xchen,
    I have dozens of WG units setup with 3CX systems. Would gadly give you a hand with it.
    1) Do you have multi-wan or just a single WAN connection?
    Here is what you need. Upgrade to a XTM515 appliance :) Just kidding
    two policies.
    Policy 1 Custom policy Ports: 5060/5090/5000/9000-9049 (Be sure to have good admin password 5000 opens mgmt from outside)
    TO: NAT ANY-External -> Private IP of 3CX server.
    Enable logging on the policy
    Policy 2 - ANY PORT
    From: Private IP of 3CX server. (Not a NAT jus the 192.168.x.x or whatever the internal is of the 3CX)
    TO: ANY-External
    Make sure these 2 policies are at the top of the WG policy list.
    If you cannot move them take the policy manager out of auto-order under View menu.
    Any questions on this shoot me a PM with your email address.
    Id be more then happy to help you get this configured if you got any questions
  4. xchen
    Aug 1, 2014
    8
    Hi mate,
    Thanks so much for your reply. I have just sent you a private message.
    I think in my case is the IP Phones who are behind the WG firewall, the 3CX Phone server is actually exposed to WWW.
    And for some reason, I only get one way audio on those Phones.
    Help. Thanks!!
