3CX or Yealink phones auto restart?
Discussion in '3CX Phone System - General' started by 805tech, Oct 9, 2014.
  1. 805tech
    Aug 30, 2013
    39
    So every day the Yealink T-32G phones restart. I am not sure what time they restart it. I know its passed 2 am when this happens but the system does not work until 7am exactly. The Yealink T-32G phones enter a continuous provisioning screen until 7am once past that they work fine the whole day. Anyone else have or had this problem?
  2. Jessep
    Oct 9, 2014
    25
    Check the settings if you log onto the web interface on the Phone itself (yealink interface) and go to the settings tab>auto provision and see if they are scheduled for a reboot.
  3. 805tech
    Aug 30, 2013
    39
    I checked that page and disabled the check new config and unchecked Sunday - Saturday. It seemed to work for a few days now its back.
  4. jasit
    jasit New Member
    Feb 12, 2013
    171
    Check your actual provision files, they might need to be changed. I have mine provision every night so they get the updated address book.
    \Templates\phones\yealinkT3x.ph.xml
    If you want to update date all your phones to use the new updated provision file, go and change the Daylight savings on the admin panel and it will use the new template to update all the phones.
