3CX Outlook Plugin Disabled Functions
Discussion in 'Windows' started by Vrig, Jun 9, 2016.
  1. Vrig
    Jun 9, 2016
    we are using the 3CX 12.5 with 3CX SoftPhone Client 12.5. After i successfully installed the 3CX Outlook Plugin (also it is been loaded in Outlook) – i can not call a contact. The ribbon bar has a new entry with “3CX” and when i select a contact i get the available telephone numbers (office, home, etc..) BUT they are greyed out and disabled, at every contact. also the right click context menu has the “call contact with 3CX” but it is disabled…
    thanks for helping!
      File size:
      28.8 KB
      1,577
  2. Desort
    Nov 21, 2011
    6
    Any news about this issue.
    In my case Outlook only shows an empty entry in the context menu for a contact instead of "Call contact with 3CX".
    And in the 3CX plugin manager there is only a "general" entry, no "Outlook".
    In Outlook the 3CX plugin is up and running.
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,375
    84
    In Outlook go to File -> Options -> Add-Ins and check if the 3CX add-in is in the Active/Available section, if not move it there, restart outlook and check again.
  4. Desort
    Nov 21, 2011
    6
    The Add-in is active.
    I'm using Outlook 2007 btw.
