3cx outlook plugin dont' work
Discussion in 'Windows' started by andrea.soc, Mar 30, 2016.
  1. andrea.soc
    Feb 24, 2016
    39
    7
    i have 3cx 14 sp3 Pro version.
    I tried to install the plugin is in tapi version, both versions microsoft outlook that installs the add-on but do not work either.
    The first gives me this error: internal error of the autodial feature and the call don't start
    The second gives me this error in attachment and paste the details of error:
    Code:
    Nome:
    Da: file:///C:/ProgramData/3CXPhone for Windows/PhoneApp//3CX Outlook Addin.vsto
    ************** Testo dell'eccezione **************
    System.Deployment.Application.InvalidDeploymentException: Eccezione durante la lettura del manifesto da file:///C:/ProgramData/3CXPhone%20for%20Windows/PhoneApp//3CX%20Outlook%20Addin.vsto: manifesto non valido o impossibile aprire il file. ---> System.Deployment.Application.InvalidDeploymentException: Firma XML del manifesto non valida. ---> System.Security.Cryptography.CryptographicException: Impossibile caricare SignatureDescription per l'algoritmo di firma fornito.
       in System.Security.Cryptography.Xml.SignedXml.CheckSignedInfo(AsymmetricAlgorithm key)
       in System.Security.Cryptography.Xml.SignedXml.CheckSignatureReturningKey(AsymmetricAlgorithm& signingKey)
       in System.Deployment.Internal.CodeSigning.SignedCmiManifest.Verify(CmiManifestVerifyFlags verifyFlags)
       in System.Deployment.Application.Manifest.AssemblyManifest.ValidateSignature(Stream s)
       --- Fine dell'analisi dello stack dell'eccezione interna ---
       in System.Deployment.Application.ManifestReader.FromDocument(String localPath, ManifestType manifestType, Uri sourceUri)
       in Microsoft.VisualStudio.Tools.Applications.Deployment.ClickOnceAddInDeploymentManager.GetManifests(TimeSpan timeout)
       in Microsoft.VisualStudio.Tools.Applications.Deployment.ClickOnceAddInDeploymentManager.InstallAddIn()
    I tried with outlook 2010 in Windows 7 and Windows 10
    thanks
  2. andrea.soc
    Feb 24, 2016
    39
    7
    I am the only one who has this problem?
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    Did you select the 3CX Plugin for Microsoft Outlook during the 3CX Plugin Setup as described in the Microsoft Outlook Integration document?
    http://www.3cx.com/docs/microsoft-outlook/
