3CX over TCP
Discussion in '3CX Phone System - General' started by hsv, Feb 21, 2011.
  1. hsv
    hsv
    Jan 6, 2011
    Is it possible to configure 3CX to use TCP insted of UDP.
    I have som customers that will like to have Snom phones at there remoted offices but not will like to have a gateway server running. They prefere a phone and not a softphone.
    Any ideas
    Regards
    Henning
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    If they have a few remote extensions at the office then they can use the 3cx tunnel. This is a small program that needs to run on a windows pc on the remote network. All phones will connect locally to that pc tunnel and the tunnel connects to the pbx on port 5090.
    This is a much better way of using it
