3CX & Panasonic KX-UT136
Discussion in '3CX Phone System - General' started by rsh, Feb 21, 2012.
  1. rsh
    rsh
    Mar 25, 2011
    18
    I'm trying to configure the Panasonic KX-UT136 to work with 3CX. Only the BLF's wont work. I've tried several parameters but it wont work.
    Has anybody got it working? I'm using firmware 01.081.
    Greetings,
    Albert
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You need to set extension number as parameter for BLF and to make correctly SIP settings into the phone
    (in this example 200, 201, ...):
    Important: Make sure your phone firmware is at least 1.025 !!, however I recommend the latest 1.081.
    This is working fine (incl. call pick-ups & holds, blind & attended transfers, etc.).
    Also you need to set correctly (in this example 244 is the extension number, 10.251.222.114 is my 3CX server):
    I'm using widely Panasonic KX-UT1xx phones and everything is working fine.
    Check also http://panasonic.net/pcc/products/sipphone/ for more details.
    Regards
