3CX & Patton SmartLink M-ATA
Discussion in '3CX Phone System - General' started by active5, May 16, 2012.
  1. active5
    Jun 28, 2011
    72
    The Grandstream HandyTone 488 is a listed VoIP gateway and the Patton SmartLink is not.
    Has anyone configured the Patton SmartLink with 3CX? Any tips?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    I have configured M-ATA, telephony is working good ()without any tricks :) ), only when i connected fax (via T.38) to M-ATA it is not working, but that was some incompatibility between my Voip provider and 3cx, otherwise M-ATA is working well in combination with 3cx...
