Solved 3CX PBX Free Edition - Not so free
Discussion in '3CX Phone System - General' started by PhoneOnline, Oct 13, 2017.
  1. PhoneOnline
    Oct 11, 2017
    6
    Big advertisements for the 3CX PBX free edition, but after one year, maintenance costs will be requested.
    I want to setup something for a home PBX with only 2-3 devices connected.
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    692
    216
    You may request new PBX free edition license key and reinstall your PBX, if you don't want to buy maintenance.
  3. easydone
    Nov 22, 2016
    8
    Then do not call it a Free PBX, it's misleading.
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    That is not entirely accurate.
    With each PBX Edition Key you get one year free maintenance. If maintenance expires, your PBX does not stop working, the only functional thing that will be affected is that the 3CX-allocated FQDN will not work anymore which would make remote extensions not to work. In the case of the OP, as its going to be a home PBX, so I assume the 2-3 devices will be local, it shouldn't cause any lack of functionality.
  5. Soho3cx
    Oct 19, 2017
    12
    Would you mind if I jump in here for a quick question? When you said remote extensions will not work anymore if maintenance expires, did you mean for STUN phones? Thanks.
  6. Sopock
    Sopock Member
    Jul 11, 2012
    444
    20
    Or any kind of phones since domain will no longer exist. I also wonder how will home user buy maintenance if company name is required field?
    With proper registration details you will get one year free maintenance as well as access to the end user portal. Check that your Company, Contact Name, E-mail, Telephone, Country and optional Reseller Name are correct.
  7. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,766
    277
    @Sopock
    Just put your name in the company name field. Not that difficult.
  8. cobaltit
    Mar 22, 2012
    1,766
    277
    So remote means remote. If you look at the options under Provisioning method I think you'll be able to figure it out.
    Technically you don't lose the ability to have remote phones, you lose the ability to have remote phones that can find the PBX via the 3CX provided domain name which stops working. The rest is up to the reader to decide what that means and how it applies to your environment
    #8 cobaltit, Oct 23, 2017
    NickD_3CX likes this.
