3cx PBX on Dedicated Virtual Server.
Discussion in '3CX Phone System - General' started by Anonymous, Oct 14, 2006.
  1. Anonymous
    Anonymous Guest
    Scenerio : multiple DID's will forward calls through SIP URI or IP to 3CX PBX extension and from extension these calls will forward to PSTN through VOIP Provider.
    Is 3CX good for this purpose?
    Also please let me know about the following.
    1. Can I use 3cx PBX on Dedicated Virtual Server, how much bandwidth is required for upto 100 extenstions.
    2. How many concurrent calls can receive and make.
    3. How many VOIP Provider I can use.
    4. What type of server configuration is required in the above scenerio.
    5. Please advise some good, Dedicated Virtual Server Provider
    6. Please advise some good, VOIP Provider for unlimited calls (Specially for Europe).
    I will must appreciate, if anyone has better solution for the same purpose.
    Regards
    Kamran
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    306
    Questions
    See answers below
    Scenerio : multiple DID's will forward calls through SIP URI or IP to 3CX PBX extension and from extension these calls will forward to PSTN through VOIP Provider. Is 3CX good for this purpose?
    I suggest running 3CX on the internal lan, not outside of your network. Otherwise all traffic has to go via the internet
    Currently each call would be 64k per second. SO it depends how many calls you expect. On a modern internal lan, this will almost never pose any problems
    There are no limits. We have tested with hundreds of simulteneous calls
    We have not included any limits in these versions.
    We recommend running 3cx phone system on the internal lan, not on a virtual server, since otherwise all traffic will have to go via the internet...
    There are many on the internet we are not in a position to recommend a particular one....
    There are many, we are not in a position to recommend a particular one
