3CX PBX, Skype Gateway, 3CXPhone on Froyo 2.2 issues...
Discussion in 'Android' started by m4f1050, Sep 7, 2010.
  1. m4f1050
    Sep 7, 2010
    14
    Ok, here is my setup:
    I have 3CX Skype Gateway setup per instructions
    ########## = phone # I am dialing from 3CX Phone (Android)
    xxxxxxx.xxxxxxxx.net = my PBX public domain
    101 = 3CX extension assigned to android phone
    72.188.15.233 = my 3G IP address
    Issues:
    When using 3G I can't send or receive phone calls.
    When using Wifi I can receive phone calls (no sound on 3cx android) but can't initiate calls, same issue as 3G, server log below:
    20:28:11.129 Requests rate from IP 72.188.15.233 is too high! Blacklisted for 167 seconds
    20:28:11.129 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:##########@xxxxxxx.xxxxxxxx.net SIP/2.0
    Via: SIP/2.0/UDP 72.188.15.233:30136;rport=30136;branch=z9hG4bKPjOXCgfI0rtGbrPdFSyPohbxinYbjlI9yV
    Max-Forwards: 70
    Contact: <sip:101@72.188.15.233:30136>
    To: <sip:##########@xxxxxxx.xxxxxxxx.net>
    From: <sip:101@xxxxxxx.xxxxxxxx.net>;tag=EEiyk9PY..FreRqYvvDsi-aEgMOXP.IA
    Call-ID: KG5WpNBt0KpivQoyMApp5dnWxx8eW5Dd
    CSeq: 4302 INVITE
    Session-Expires: 1800
    Min-SE: 90
    Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
    Supported: replaces, 100rel, timer, norefersub
    User-Agent: 3CXPhone for Android 1.1.13
    Content-Length: 0
  2. m4f1050
    Sep 7, 2010
    14
    Ok, using FRING here is the log, but this time I can receive calls on both LOCAL and 3G and I can listen to calls as well, just can't make calls on 3G or LOCAL....
    101 = extension I have routed through Skype Gateway
    208.122.63.100 = 3G IP address
    22:00:36.487 Requests rate from IP 208.122.63.100 is too high! Blacklisted for 167 seconds
    22:00:36.487 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:{dialed phone #}@{my public domain} SIP/2.0
    Via: SIP/2.0/UDP 172.16.13.193:55044;branch=z9hG4bK11e20951330219108783cdb029658307;rport=55044;received=208.122.63.100;iid=2
    Max-Forwards: 70
    Contact: <sip:101@208.122.63.100:55044>
    To: <sip:{dialed phone #}@{my public domain}>
    From: <sip:101@{my public domain}>;tag=11e20951330219108784cdb029658307
    Call-ID: 4db60651-3302-1910-9050-cdb029658307
    CSeq: 4711 INVITE
    User-Agent: fring
    Content-Length: 0
    22:00:36.486 [CM302001]: Authorization system can not identify source of: SipReq: INVITE {dialed phone #}@{my public domain} tid=11e20951330219108783cdb029658307 cseq=INVITE contact=101@208.122.63.100:55044 / 4711 from(wire)
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    First of all, can you even call your PBX's 999 VoiceMail or any other extension before even routing it through the skype gateway?
    Secondly i'd suggest you try giving your system more relaxed security settings, by going to: Settings > Advanced > Anti-Hacking and settings everything to 9999
  4. m4f1050
    Sep 7, 2010
    14
    Nope, cant call 999
    Set everything to 9999 on the security section, It still gets blacklisted...?
  5. LeonidasG
    Nov 19, 2008
    1,557
    118
    Can you explain the nature of the call?
    You are an Android Phone trying to call what? Where are you connected? How does the Skype Gateway fit in all this?
  6. m4f1050
    Sep 7, 2010
    14
    Well, right now don't even worry about the Skype gateway, it is just used to route skype calls in and out through an extension on the PBX using SIP on android.
    Right now it doesn't even call another extension. I stopped all the services and installed Axon Virtual PBX and it all works and in just seconds! BUT it doesn't route my calls from and to my skype account like 3CX does. So right now I am trying to concentrate on the 3CX communicating me from extension to extension which is not doing, it "blacklists" my device when I just try to call an extension (or basically when I call anything...)
  7. LeonidasG
    Nov 19, 2008
    1,557
    118
    Could you send me a backup of your system at lg@3cx.com
  8. LeonidasG
    Nov 19, 2008
    1,557
    118
    From the logs you've sent me, i can only see calls made by Fring.
    There don't seem to be any calls from an 3CX Android Phone.
  9. m4f1050
    Sep 7, 2010
    14
    Because the 3CX phone call doesn't even go out and reach my PBX. I am trying to fix the PBX software on my PC right now.
