3CX PBX v.10 management console(remote)
Discussion in '3CX Phone System - General' started by Sergiy, Jan 10, 2014.
  1. Sergiy
    Dec 12, 2011
    15
    Hi all.
    I have installed 3CX PBX v.10 at my enterprise's server, so is possible to manage it over WebGuiInterface.exe from client workstation? In my case I can't to manage over web browser IE11 that doesn't support VisualWebGui (here error message Version Information: Gizmox Visual WebGui Framework Version: 6.3.8a), other browsers aren't desirable. So, change value [ConfService]\confNIC to LAN interface works just for config storage service (I can see that with netstat), but phone system service doesn't start and WebGuiInterface.exe fails to start too with message the config server not configured. Is this setting hardcoded with value 127.0.0.1 to application or where I can change it?
    Thanks.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    You will find some of your answers here:
    http: //www.3cx.com/manual/3CXPhoneSystemManual10.pdf - NO LONGER AVAILABLE. NEW LINK: http://www.3cx.com/docs/manual/
    you can use I.E.11 by simply adding the website of the console to the compatibility view settings under Tools on I.E.11; alternatively you can try Chrome and/or Mozilla. All 3 work well.
    I am uncertain if the thread is only dealing with one issue or more. You seem to be indicating that perhaps there is a conflict in port usage, but I am not sure of this.
  3. Sergiy
    Dec 12, 2011
    15
    I didn't know that IE11 still has compatibility mode (cause button with "broken" page was removed). Now it works fine.
    Thank you very much! :)
