3CX PBX v12.5 on Windows 10?
Discussion in '3CX Phone System - General' started by complex1, Sep 26, 2015.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    813
    46
    One of my customers want to upgrade his 3CX server from Windows 8.1 to Windows 10.
    Is there someone who can confirm if 3CX Phone System v12.5 runs well on Windows 10 Pro, because the Admin manual does not saying anything about this.
    Thanks.
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Here's a grab from a google search "3cx requirements" which took me to a 3cx.com page. As you can see, it does not state Windows 10. That is probably because Windows 10 was not in the wild at the time of this list. Most likely 12.5 will run on Win10 but that is just my hunch.
    Regards,
    Allen
    3CX Phone System Version 12.5
    Windows 7 Professional (x64)
    Windows 7 Ultimate (x64)
    Windows 7 Enterprise (x64)
    Windows 8 Pro (x64)
    Windows 8 Enterprise (x64)
    Windows 8.1 Pro (x64)
    Windows 8.1 Enterprise (x64)
    Windows 2008 R2 Foundation (x64 only)
    Windows 2008 R2 Standard (x64 only)
    Windows 2008 R2 Enterprise (x64 only)
    Windows 2008 R2 Datacenter (x64 only)
    Windows 2012 Foundation (max. 15 presence connections on IIS installations)
    Windows 2012 Essentials (max. 25 presence connections on IIS installations)
    Windows 2012 Standard
    Windows 2012 Datacenter
    Windows 2012 R2 Essentials (max. 25 presence connections on IIS installations)
    Windows 2012 R2 Standard
    Windows 2012 R2 Datacenter
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    You can always fire up a test machine... but since the PBX is such an integral part of a business, I would generally hold off a bit until 3cx officially supports it. No need to make any changes if the PBX is working ok.
  4. complex1
    Jan 25, 2010
    813
    46
    @Allen, @Craig
    Thank you for the response.
    Regards.
  5. complex1
    Jan 25, 2010
    813
    46
    To reply my own post…
    The customer upgraded a few days ago to Windows 10 Pro
    So Yes, I can confirm that 3CX Phone System v12.5 runs well on Windows 10 Pro.
    Just want to let you know.
    Thanks.
  6. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Please be aware that 3CX Phone System v12.5 has not been tested on Windows 10. Therefore no support can be offered for this.
    The supported operating system are as the 12.5 Admin manuals states. http://www.3cx.com/manual/3CXPhoneSystemManual125.pdf
  7. complex1
    Jan 25, 2010
    813
    46
    Charalambos, thank you for your reply.
    I am aware of that.
  8. red45
    Nov 4, 2014
    62
    15
    v14 sp1 is officially supported by 3CX on windows 10.
  9. adrianc
    Sep 4, 2015
    20
    We've got a couple of clients running 12.5 on Windows 10 without any issues.
