3CX PBX Voiptalk registration failed
Discussion in '3CX Phone System - General' started by miro, Jan 30, 2012.
  1. miro
    Jan 17, 2012
    51
    Hello
    we have problem with registering 3CX PBX to Voiptalk SIP server, we recieve 403 Forbbiden - no OBP message:
    REGISTER sip:77.240.48.94:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.160.250.130:5060;branch=z9hG4bK-d8754z-6e3ba13e9c40ca07-1---d8754z-;rport
    Max-Forwards: 70
    Contact:
    To:
    Call-ID: NGE3NGRmOWE0N2E2NjJkNTg3OWIxYTk3YTFlMTQ0N2E.
    CSeq: 1 REGISTER
    Expires: 60
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Supported: replaces
    User-Agent: 3CXPhoneSystem 10.0.22539.0
    Content-Length: 0
    SIP/2.0 403 Forbidden - no OBP
    Via: SIP/2.0/UDP 10.160.250.130:5060;branch=z9hG4bK-d8754z-6e3ba13e9c40ca07-1---d8754z-;rport=5060;received=89.201.173.151
    To: ;tag=3eeda7e8f0549c38df1ae575f0b8a0ef.3534
    CSeq: 1 REGISTER
    Server: OpenSIPS (1.6.2-notls (i386/linux))
    Content-Length: 0
    We checked our Firewall and from that perspective everything is ok.
    Could you please give us advice how to solve this problem.
    Thanks.
    10,767
    286
    OBP= Outbound Proxy
    Are you missing something in your trunk settings?
    http://www.voiptalk.org/products/3cx-pbx-voiptalk-trunk-guide-setup.html
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    the outbound proxy should be set to nat.voiptalk.org
    if you continue to get issues, you can leave this out and it should register ok.
    the outbound proxy is not always required to get 3CX working with VoIPTalk.
  4. miro
    Jan 17, 2012
    51
    We tried again with template and it works ,thanks for help.
