ALready saw this article...not much help. As I mentioned I already have the certificate. Also, Google cloud now provides free managed SSL certs and it is automatically enabled in the instance. SO how do I get past this step. Very frustrating. Also the article says how to order a certificate and not show steps how to install/upload it first before starting the install. So a bit vague as now I am stuck in the stupid SSL cert step and the file does not exist. Why not use the google managed cert? Maybe 3CX needs to update the install script and not bother with a cert until after the install. Or better yet fix the pbxexpress install so after you enter a pro license it will allow you to enter your own fqdn and not force you to use theirs. It already allows you to use your own google cloud instance, so why not fqdn?
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
