3CX/PfSense: Outbound "Not Available"
Discussion in '3CX Phone System - General' started by oguruma, Feb 24, 2017.
  1. oguruma
    Feb 18, 2017
    15
    Running 3cX w/PIAF. I only have the Windows 3CX softphone for the time being. I use Flowroute and I have 2 DIDs from them.
    I can dial into and take calls on the softphone via 3cx from outside the network.
    I can dial out using the softphone when connected to sip.flowroute.com.
    When I try to dial out using the softphone via 3cx, I get "not available".
    My 3cx box passes the firewall checker.
    I have the same issues with both of my DIDs.
    The 3CX call log shows:
    Date/Time From To Talking
    02/23/2017 9:03:56 PM Me (0000) 1555-555-5551 1555-555-5552 Not Answered
    Anybody have any ideas? My 3cx is registered to Flowroute successfully (or I couldn't make outbound calls).
    I have configured my PfSense based on the following. https://www.3cx.com/blog/voip-howto/pfsense-firewall/
    #1 oguruma, Feb 24, 2017
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi oguruma,
    Did you setup your flowroute account on your soft phone directly?
    Do you mean that you can receive incoming calls and when the clients are outside from LAN can call between them?
    Did you try to add a simple outbound rule?
  3. oguruma
    Feb 18, 2017
    15
    Just to clarify, I have 2 profiles on my 3cx softphone. One is for my flowroute account, without the 3cx box. The other is for 3cx. The profile that is connected directly to flowroute make make and receive calls without issue. The profile connected to the 3cx box can only receive calls.
    I can receive calls on the 3cx profile, even from my cellphone or any other landline.
    I added the outbound rules found here https://support.flowroute.com/customer/en/portal/articles/2523606-configure-3cx-15
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi oguruma,
    Could you please send us a screenshot of your outbound rules? Also please give us a sample of the number that you try to call.
  5. Patrick Hogan10
    Nov 23, 2016
    27
    Any resolution to this yet? Sounds like a problem with the outbound rules.
  6. GiannosC_3CX
    GiannosC_3CX Guest
    Hi oguruma,
    Could you please update the post on your findings and if you managed to solve the issue, we would be grateful if you could share it with the community.
  7. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    What version?o_O
    https://www.3cx.com/docs/manual/managing-ip-phones/#h.yqcpkxsi2a04
