3CX Phone 12 and 3CX server 10,11) don't register
Discussion in '3CX Phone System - General' started by bigsrl, Feb 18, 2014.
  1. bigsrl
    Jul 11, 2013
    7
    Hello everyone
    First i don't know why i can add a topic in "3CX windows phone" forum section; in particular i need to add a post here: http://www.3cx.com/forums/3cx-phone-wont-register-with-server-38282.html but i can't :cry:
    anyhow, i have many customer running 3CX server (version 10,11) now i try to use the new client 3CX 12...but it won't register
    the parameters are the same; the server didn't see any login question from client and i don't know WHY in 3CX client log i find many request to "http://192.168.77.69:5000/MyPhone/MPWebService.asmx" and no request to port 5060 (the default SIP port!)
    192.168.77.69 is the address of server
    any other SIP client with same parameter work properly... but 3CX client with 3CX server NOT. :lol: :lol: :lol:
    Why??????
    thanks for the answer
    Bye
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    The versions prior to V12 require MyPhone and/or Windows Phone v6. The current client is not backwards compatible.
  3. bigsrl
    Jul 11, 2013
    7
    my CLIENT don't work, NOT SERVER!
  4. lneblett
    Sep 7, 2010
    2,086
    65
    You said:
    anyhow, I have many customer running 3CX server (version 10,11) now i try to use the new client 3CX 12...but it won't register
    I said:
    The current client (meaning v12) is not backwards compatible.
    In other words, the V12 client software is not usable with V11, V10, V9, etc. You can only use the V12 client with the V12 Editions of 3CX.
    The earlier versions v11 & v10 were based upon Silverlight. This is not the case with V12. The V12 client has integrated the soft phone functionality along with presence information such that it is a single application.
  5. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Don't get mad.. get a compatible softphone:
    http://www.3cx.com/downloads/3CXPhone6.msi
  6. bigsrl
    Jul 11, 2013
    7
    Hello
    thanks for the answer, i thought trivially that 3CX is a very easy and powerful client; but if don't support a 3CX phone system older than 3CX12 and it can't work with a non-3CX server....it's a useless client
    sin once were doing smart things :roll:
    you can close 3D
    bye, thanks for the support
  7. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Bigsrl:
    Sarcasm aside, the 3CX client for V12 is one that packs a ton of features geared to V12. You can use the actual 3CX softphone (6) and use that with ANY version of 3CX. It isn't 3CX's fault... or just upgrade your clients to the current version (better idea) V12...
