3CX Phone 14-Connect-Timeout-Connect-Timeout-Conntected cycle
Discussion in 'iOS' started by m.loosli, May 30, 2016.
  1. m.loosli
    May 30, 2016
    9
    Devices Info
    Phone Model: iPhone
    Generation: 5s, 6 and 6s
    Firmware Version: 9.3.2
    Jailbreak: no
    Issue Info
    Handset: Phone
    Connection: Wifi and 3G
    Server: Internal
    Every time I open the 3CXPhone 14 App the phone needs about 30 seconds to provision the presence information and the contacts; SIP is connected in about 1-5 seconds.
    The ports 5060 5090 443 and 80 are open and redirected to 3cx. When I connect from the internal network, everything works fine/fast. The problem only occurs from "outside".
    When I capture the packets I see the https- requests/responses and nothing indicates a port forwarding problem.
    3cx is setup with a separate FQDN for the internal and external network.
    Thanks for your help
    Best Regards,
    Markus Loosli
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,367
    83
    Does the internal FQDN you have used also resolve externally or is it something that only resolves from inside the network where the 3CX Server resides?
  3. m.loosli
    May 30, 2016
    9
    It only resolves from inside the network; I'm using a .local domain and a top level domain.
  4. PatrickTodd
    Jan 12, 2016
    40
    6
    Same setup here; external FQDN is a TLD whereas internal is a .local (ugh, legacy setup crap)
    1:1 NAT is properly setup and SIP calls function just fine but 3CX phone app constantly says it is not connected and does not show presence info.
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,500
    67
    A good test is to try to access the PBX's management console directly from your iPhone's Safari browser (ie something like https: //vali3cx.3cx.pbx:5001/management/MainForm.wgx) If Safari isn't able to open that page, 3CXPhone will not be able too to connect the MyPhone server.
  6. m.loosli
    May 30, 2016
    9
    Hi Vali_3CX
    The management console is available from iPhone and instantly shown without timeout. Same for the URLs in the provisioning-file (myphone/ and provisioning/).
    3CXPhone is able to connect to the MyPhone server, but runs into a timeout for the first two attempts.
  7. m.loosli
    May 30, 2016
    9
    More things I can check? Or is it already clear that it's a bug and you're fixing it?
  8. m.loosli
    May 30, 2016
    9
    Is there something more I can check?
  9. complex1
    complex1 Active Member
    Jan 25, 2010
    803
    45
    - Is the "outside" a LAN/Wifi or 3G network?
    - Have you tried to use a other iPhone (if possible)?
    - Have you reinstall the app?
    - Is it possible to connect/register your iPhone to another PBX?
  10. m.loosli
    May 30, 2016
    9
    Thanks for your assistance.
    From the WAN, Wifi or 3G doesn't matter.
    Yes, same behaviour.
    Yes, tried this twice on both iPhones.
    Yes, the problem only occurs on my Installation. The 3CX of my colleague connects in an instant but he uses a split dns installation.
    Connecting with Zoiper to 3CX works fine from WAN and LAN.
  11. complex1
    Jan 25, 2010
    803
    45
    Just for testing… After provisioning the iPhone with the welcome mail please change the External PBX IP FQDN into the WAN IP-address and check if the issue still exist?
    The iPhone don’t have to resolve the public IP address of the PBX
  12. m.loosli
    May 30, 2016
    9
    Hi complex1,
    The issue still persists after reprovisioning and setting the external IP to the WAN IP.
    SIP connects in an instant and the "availability"-part uses 3 cycles to change to "available".
  13. complex1
    Jan 25, 2010
    803
    45
    Hi Markus,
    So, a long story short… you have issues with ports 80 / 443 (Presence Info)
    What I like to know:
    - Are you sure these (router) ports are dedicated to the 3CX PBX and nothing else?
    - Probably nothing to do with it, but is SIP_ALG disabled?
    - Did you restart the IIS web server?
  14. m.loosli
    May 30, 2016
    9
    Hi Frank,
    Yes, I think so too. The strange thing is that only the app is affected.
    - Port 80/443 are open and redirected to 3CX
    - SIP_ALG is disabled
    I made a change in the security tab and will reboot the whole server this evening. Last time I restarted the Server was last thursday.
    I'll keep you informed.
  15. m.loosli
    May 30, 2016
    9
    Hi Frank,
    The problem still persists even after the restart. To stay sure I even reprovisioned the iPhone but the behavior stays the same.
  16. complex1
    Jan 25, 2010
    803
    45
    Hi Markus,
    Very frustrating...
    For now I don't have other suggestions to do.
    Maybe you have to consider a reinstall of the 3CX PBX.
