3cx phone 5 and 6 voice problem
Discussion in 'Windows' started by WingDog, Nov 9, 2012.
  1. WingDog
    Nov 9, 2012
    Hi!
    I've using softphone 6 at windows 7 x64, which connected to asterisk and G711alaw codec on it.
    when someone calls me, or I'm calling to someone there is a strong noise and something like car alarm from my side, but I hear them flawless.
    any ideas how to fix it?
    thanks
    11,105
    329
    Unless you can duplicate this on a second machine, it may be an issue related to something (hardware/software) on the particular PC that you are using.
    Have you tried registering with any other PBX/provider, to see if the noise happens, with them?
