3CX Phone and Citrix?
Discussion in '3CX Phone System - General' started by tom_ch, Sep 14, 2014.
  1. tom_ch
    Jul 6, 2011
    69
    Hi folks
    has anyone of you made experience with 3CX Phone in a Citrix Terminalserver environment? (Windows Server 2008 R2)
    Thanks for sharing :)
    Regards
    Tom
  2. AndreasA_3cx
    AndreasA_3cx Guest
    Hello Tom and thank you for contacting us.
    Unfortunately Citrix is not a supported virtualization method, the only supported are HyperV and VMware.
    Kind Regards
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,083
    10
    HyperV and VMware are related to 3CX PBX server itself,
    Citrix is related to desktop virtualization and 3CX Phone client.
    Should be working, if you manage to have virtual audio card working, the 3CX Phone will stop work if no audio card is recogniized after V12 SP4.
  4. tom_ch
    Jul 6, 2011
    69
    thank you very much for your answers.
    We use VMware as virtualization platform, should have mentioned that...
    is the 3CX Phone fully working on a Terminalserver? How about TAPI?
    King regards
    Tom
