3CX Phone API
Discussion in 'Windows' started by Eli55, Jan 2, 2017.
  1. Eli55
    Jan 2, 2017
    19
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You can add queue name to caller's name (in Company Phonebook for v.14 or Contacts for v.15 settings), this way you can see which queue was called. You may organize many queues to match all your incoming numbers.
