3CX Phone App does not Dial Desk Phone (CTI) since Update
Discussion in 'Windows' started by ckatterl, Aug 10, 2017.
  1. ckatterl
    Nov 15, 2016
    55
    6
    Yesterday, I updated to 15.5 SP1
    For SNOM D345 there was a firmware-update needed.
    Now, 3CXPhone cannot dial via CTI any more.
    Any suggestions?
    BR, Christian
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    12
    Can you also update the templates?
    1. Go to Dashboard > Updates and perform updates.
    2. You will see Phone Templates update for Snom (Look screenshot)
    3. Select and download
    4. Then go to Settings > Templates and from the drop down list select Snom template.
    5. On the top of the XML template make sure that the Version is 68850:
    <type>phone-template</type>
    <version>68850</version>
    6. Perform Re-provision and CTI will work
    Thank You
  3. ckatterl
    Nov 15, 2016
    55
    6
    thanks for the feedback.
    Unfortunately, there's no update for the templates available..it does not show up.
    The version in the xml is 68849 now...
    BR, Christian
  4. Marios Neophytou
    Mar 1, 2016
    258
    12
    Do you have a Snom phone already configured on the PBX? If no then the updates will not appear on your system.
    Thank you
  5. ckatterl
    Nov 15, 2016
    55
    6
    Currently, there are around 250 snom phones configured ;-)
  6. Marios Neophytou
    Mar 1, 2016
    258
    12
    I have sent you a PM
    Thank You
  7. Richard Bandion
    Mar 20, 2017
    basically same Problem here - Updated Snom D375 to current firmware und 3CX Clients to 15.5 SP1 (At the same time...), and CTI stopped working. (We are using customized templates.)
    Can you please provide the solution here instead of PM? Thank you.
    Richard
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
