3cx phone app on windows
Discussion in '3CX Phone System - General' started by AZ-Brad, Jun 29, 2017.
Tags:
  1. AZ-Brad
    Jun 29, 2017
    22
    Running lastest version of phone app
    Running 15.5 pbx
    We have moved to softphones on most of our workstations and it has been working very well except we never know when there is a call on SP0 or SP1 (we only use 2 sp's)
    Anyone know if there is a way to make the app indicate like the other BLF's when a SP is in use?
    Thanks!
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi There
    If you have BLF status changes for other extensions then can i presume this is not a free license but rather pro or standard. So i presume the buttons are Grey?
    In which case this is a simple matter of rights. From the management console navigate to an extensions settings and from the rights tab and check the option for 'Can park calls'. This will then display the Keys in green and will turn Red when there is a parked call.
