3CX Phone book - importing contacts
Discussion in 'Ideas' started by r.towle, Oct 20, 2015.
  1. r.towle
    Apr 11, 2013
    67
    10
    When importing contacts to the 3cx phone book, could this be changed so that one contact can have more than one number?
    Typically, our clients give us huge lists of contacts to import, and generally, one contact has 3 or 4 numbers - work, mobile, home, fax etc
    The other option would be for 3cx to have the back-end ability to connect directly to an exchange address book or books and for it to pull data directly from exchange.
  2. solutionsit
    Nov 25, 2014
    62
    5
    Give this a go. If you use Yealink phones this is a good work around
    This is not supported by 3cx but works for us
    http://www.3cx.com/forums/post173874.html#p173874
  3. r.towle
    Apr 11, 2013
    67
    10
    Thanks for this. We will have a look at this.
    Regards
