Solved 3CX Phone Book on Yealink
Discussion in '3CX Phone System - General' started by xirgo, Jan 31, 2017.
  1. xirgo
    Nov 9, 2015
    22
    Anyone know how to change the display option on the 3CX phonebook on Yealink phones to show Firstname, Last name instead of lastname, firstname?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    Hello @xirgo
    This can be changed from the contacts tab in the management console (in V15). Click on contacts/ options and select Last name /First Name
    xirgo likes this.
  3. xirgo
    Nov 9, 2015
    22
